View MLT Port Members
View the port members in the specified MLT, or for all MLTs.
The show mlt [<1-512>] command displays remote port members only if the MLTs are configured on vIST peers that use the same MLT ID.
If the MLT is between two devices that use the same MLT ID, but they are not vIST peers, show mlt [<1-512>] does not display the remote port members in the output.
In this first example, MLT 512 is an MLT between two vIST peers with the same ID used on both peers. In this case, the output displays the remote port members.
Switch:1(config)#show mlt 512
                                    Mlt Info
                        PORT    MLT   MLT        PORT         VLAN
MLTID IFINDEX NAME      TYPE   ADMIN CURRENT    MEMBERS       IDS
512    6655   MLT-512    trunk  norm   norm     1/24         1000 2000
               DESIGNATED   LACP      LACP
MLTID IFINDEX  PORTS        ADMIN     OPER
512    6655    null          disable   down
                                                               WHICH PORTS
                WHERE      LOCAL             REMOTE            PROGRAMMED
MLTID NAME      CREATED    PORT MEMBERS      PORT MEMBERS      IN DATA PATH
512   MLT-512   LOCAL        1/24              1/22              LOCAL
               ENCAP                         PVLAN        VID
MLTID IFINDEX  DOT1Q     LOSSLESS   PVLAN    TYPE         TYPE         FLEX-UNI
512   6655     enable    disable   disable   -            -            disable
In this second example, MLT 1 is an MLT between two devices that are not vIST peers so the output does not display the remote port members.
Switch:1(config)# show mlt 1
                                    Mlt Info
1      6144   MLT-1    trunk   norm   norm     1/5          1000 2000
1    6144      1/5          disable   down
                                                               WHICH PORTS
1     MLT-1     LOCAL       1/5                                LOCAL
               ENCAP                         PVLAN        VID
1   6144     enable     disable    disable   -            -            disable
Variable definitions
Use the data in the following table to use the show mlt error collision command.
| Variable | Value |
| <1-512> | Specifies the MLT ID. The value ranges from 1–512. |
